Fax API Call Help
  • 18 March 2018
  • 358 views
Body:
{ "message" : "Unsupported Media Type", "errors" : [ ] }
Header:
X-Rate-Limit-Window : 60
Status_Code : 415
RoutingKey : SJC11P01PAS01
Http_Version : HTTP/1.1
Explanation : Unsupported Media Type
Connection : close
Content-Language : en-US
Date : Sun, 18 Mar 2018 02:55:08 GMT
X-Rate-Limit-Group : heavy
Server : nginx/1.10.2
RCRequestId : c479c8b0-2a57-11e8-a5f0-005056bb594d
Content-Type : application/json;charset=UTF-8
X-Rate-Limit-Limit : 10
X-Rate-Limit-Remaining : 9
Content-Length : 60
Code:
To decipher Coldfusion, I am telling it to submit a multi-part form encoded in UTF-8. I know most of you don't know Coldfusion, but you can see my variables below...do I even have the correct variables here?
<cfhttp method="post"
url="#final_url#"
multipart="yes"
resolveurl="no"
charset="utf-8"
name="faxes"
<cfhttpparam type="header" name="authorization" value="#authorization#">
<cfhttpparam type="header" name="content-type" value="text/plain">
<cfhttpparam type="formField" name="to" value="#ringcentralFax.toFaxNumber#">
<cfhttpparam type="formField" name="faxResolution" value="#ringcentralFax.faxResolution#">
<cfhttpparam type="formField" name="attachment" value="#faxFileName#">
<cfhttpparam type="file" name="#faxFileName#" file="#faxFilePath#">
</cfhttp>
I haven't used Cold Fusion but the following content type looks incorrect:
The HTTP request header should be "mutipart/form-data" instead of "text/plain".
To spot check your entire request, you should inspect the HTTP request headers and body that is constructed. You can dump this yourself or send it to a service like RequestBin (https://requestb.in/).
Your HTTP request should look something like the example in the Developer Guide:
http://ringcentral-api-docs.readthedocs.io/en/latest/messages_faxes/
