Jensen Zhao avatar image
Jensen Zhao asked Phong Vu answered
Incoming Webhook not working
Hi all,
I created an Incoming Webhook URL for a Glip group, but it just can't pass the test.
Tried this command in the terminal, I'm using a MacBook.
curl -d '{"text": "sdfsd"}' -H 'Content-Type: application/json' my_webhook_url
It has an error message like the below:
{"status":"error","message":"Your request was accepted, however a post was not generated","error":"Invalid Custom payload: no supported fields","validation":[]}
webhooks
1 |1500
1 Answer
Phong Vu avatar image
Phong Vu answered
The new version of Glip webhook use the "body" instead of "text"
curl -d '{"body": "sdfsd"}' ...
1 |1500
Developer sandbox tools
