Roger Samuel avatar image
Roger Samuel asked Roger Samuel answered
Error sending an MMSmessage
When I try to send an MMS message I get:
{ "errorCode" : "InvalidParameter", "message" : "Parameter [attachments] value is invalid.", "errors" : [ { "errorCode" : "CMN-101", "message" : "Parameter [attachments] value is invalid.", "parameterName" : "attachments" } ], "parameterName" : "attachments" }
Does anyone know what's wrong? I have the JSON formatted properly and it worked in the sandbox. Now it does not work in production.
errors
1 |3000
Roger Samuel answered Phong Vu commented
Is there anything else I can try? I'm stuck right now?
2 comments
1 |3000
Things must be in your code then. Does it work with just SMS text?
Are you ready to try e.g. the Node JS SDK?
0 Likes 0 ·
I see you are trying to provide service to RingCentral users to use P2P SMS (consumer) for A2P SMS (non-consumer), you will soon cause them getting blocked by mobile carriers.
Are you available for a quick call so I can walk you thru a process and better options? If so, let me know your email address.
0 Likes 0 ·
Roger
888.205.6032
roger@vortext.ca
1 |3000
Another issue, it does not even work in the portal "TRY API" option
1 comment
1 |3000
BTW, I check your production account and you don't have one. You signed up for a free tier sandbox account and you created a public app so that other RingCentral customers can login your app with their own credentials to send SMS.
Now tell me how did you try to login the production? Do you login with a customer credentials? If so, what is their account id?
0 Likes 0 ·
Yes, my client used my app for their live account . The main login number of their live production account is 720 465 6809
1 |3000
Any more suggestions?
1 |3000
Developer sandbox tools
