Why are incoming calls not showing as currently calling? Notification is only received when call is missed. Number is active and should receive calls 24/7. Is there another setting that could be making this happen?
Are you using API to initiate the inbound call (ring out or callout? ). What device type are you using to receive the calls?
Can you check if you have enabled DND status ?
Can you check your Call Handling and Forwarding rules on service.ringcentral.com and verify If that's correct?
You can reach out to RingCentral's Techsupport team for further assistance if you are not using any APIs or API integration products : https://support.ringcentral.com
5 People are following this question.
O@H "Phone Number Name" not appearing on inbound calls for desktop integration within Outreach
need call transfer to allow caller/transferee to stay on call
Request Feature - drop-down to select from common locations for emergency services (e911)
Audit Trail should show if user downloaded calls or heard the recordings
embeddable widget change fromNumber dynamically when calling out
