Gwen Pielstick avatar image
Gwen Pielstick asked ·
Incoming Fax busy signal?
I use ringcentral in my home office. I recently tried to receive a fax and the sender said they got a busy signal. Can you please tell me why that would be and how to fix it? Thanks, Gwen
1 Answer
· Write an Answer
Tracie Good avatar image
Tracie Good answered ·
Did you ever find a solution to this problem.  We are experiencing the same issue this morning & I see no settings that could solve the problem.
