patrick1 avatar image
patrick1 asked ·
Inbound Call Problems
Has anyone else had problems receiving inbound calls from only particular carriers?  All of a sudden starting yesterday, some of our RC numbers can not receive inbound calls from particular carriers (ie AT&T wireless & Verizon Wireless), yet calls from other carriers go through as normal.  This is very frustrating and many of our customers are getting a recording saying the call cannot be completed as dialed.  Help!
inbound callscarrier
patrick1 answered ·
No, all were ported over a year ago and fully functional since.  Though each of the affected numbers come from a single area code and prefix.  Unaffected RC numbers have same area code but different prefix.
Dustin Showers avatar image
Dustin Showers answered ·
Recently ported?
Jeff J avatar image
Jeff J answered ·
One of our offices seems to be having issues with receiving calls from AT&T land lines.
Matthew Weaver avatar image
Matthew Weaver answered ·
We are having the same problem with one of our lines.  It is a bit intermittent but it is clearly happening.
Anyone have an update on this?
patrick1 answered ·
Our original problem resolved after about 5 days.  I believe some of the behind the scenes inter-carrier settings get misaligned and eventually it gets fixed, but i have no way to know for sure. It may also have be related to a ringcentral update that came out at the same time.  Ringcentral support were unfortunately not able to help at all on this issue.
Michael Semenovski avatar image
Michael Semenovski answered ·
same issue in my 413 area code, I'm loosing business because of that
1 comment Share
Hi Michael,  If you, or anyone else is still having a problem with this be sure that you don't have any area codes blocked and if it still does not work, you are welcome to  Open a Case.  Be sure to include as many details as you can; date time, carrier, any related information you can provide will help.
Mike
0 Likes 0 · ·
