eddie123 avatar image
eddie123 asked ·
Independant voip control for incoming vs outgoing calls.
Is there a way to receive calls via voip, but set the app so when you place an outgoing call it always uses the phone instead of voip? It gets annoying having to turn voip calls of to make an outbound call because I always forget to turn it back on.
1 Answer
· Write an Answer
mike avatar image
mike answered ·
Hi Eddie,
There's not an independent control for incoming vs outgoing calls. However, you can likely accomplish the functionality you are looking for by turning off voip on the mobile app, and then using forwarding rules to answer calls on your mobile phone.   Here are a couple help topics depending on if you have an Android or iOS.   Click the 2nd link and scroll to the bottom of the page and read the section titled "Things to know: Incoming VoIP Calling", and I think this will help you out.
Enabling VoIP calling on your iOS mobile app
Enabling VoIP Calls over WiFi or 3G/4G LTE Data Connection on Android
Mike
