Kyle Anthony Hill avatar image
Kyle Anthony Hill asked ·
Caller ID in Salesforce does not work for call groups
There is currently no way to sync RingCentral contacts with Salesforce contacts.
I understand if you call each line directly and the Salesforce app will ring. But if you call the line as part of a call group then Salesforce does not get notified and the contact does not show up.
This literally makes RC useless to us.
WE NEED CALLER ID WHEN SOMEONE CALLS US!! WHY HASN'T RC BUILT THIS??!
No one calls each user's phone directly -- that's pointless.
caller idsalesforce
1 comment
Happy to help!  Sorry if you had a bad experience with the phone support. Feel free to use this Community in the future if you have more questions and don't hesitate to post a new question if you can't find an answer or solution.
Thanks!
Mike
0 Likes 0 · ·
1 Answer
· Write an Answer
mike avatar image
mike answered ·
Hello Kyle,   If I understand you correctly, the problem has to do with the way you are routing your calls.
Take a look at this video, and set up a Group(Department) and then I think this will solve your problem.
