jenisha avatar image
jenisha asked ·
Can anyone help me out to get the solution for error code 3 in Ring Central Fax API integration Responses i.e., "No Recipient Specified"?
Can anyone help me out to get the solution for error code 3 in Ring Central Fax API integration Responses i.e., "No Recipient Specified"? I am getting all time the same response when I am passing the Recipient Fax Number.
1 Answer
· Write an Answer
mike avatar image
mike answered ·
Hi Jenisha, for this issue, you can send an email to  devsupport@ringcentral.com
Mike
