alyssia avatar image
alyssia asked ·
Queue Name Display on Incoming Calls
How can I display the queue name for incoming calls?  I would like to use a different script based on the inbound queue and would like to display the queue name when an agent receives a call.
rob.benn-frenette avatar image
rob.benn-frenette answered ·
You can't change the name of the call as far as I know, but you can set the system to tell the call receiver to press one to accept the call from the "ABC Call Queue"
kim avatar image
kim answered ·
Rob is correct in this situation.  Thank you very much for your help her, Rob.
Kim
