ringcentral avatar image
ringcentral asked ·
Is RingCentral Meetings using the same settings for voice calls?
RingCentral Meetings is using same settings for voice calls ? Note: This conversation was created from a reply on: How do I troubleshoot Call Quality issues - QoS?.
1 Answer
· Write an Answer
mike avatar image
mike answered ·
Hi Claudio,  I moved the post here because the issue you have explained regarding the video not working sounds like a setting or configuration issue on the computer or tablet.  RC Meetings does not use the same signalling unless you are calling the conference number.
Go to settings on the iPad and make sure the RingCentral app has permission to use the camera.
Settings > Privacy > Camera and set the RC Meeting switch to the "on" position.
Mike
