ghostraker avatar image
ghostraker asked ·
fax will not auto print
Any printer I choose I get told it cannot print
mike avatar image
mike answered ·
The first thing to check is that you are using the most recent version of the RC Desktop. Can you tell us what version you are on?
kim avatar image
kim answered ·
Do you still need assistance?
ghostraker answered ·
I have the most current version available. I select a printer from the printers listed for my machine and I find that it does nothing.
1 comment Share
Can you check the version number?  We are in the middle of pushing out some updates, but not every user gets the updates right away.
0 Likes 0 · ·
