Lori Collins avatar image
Lori Collins asked ·
No sound on some calls using a fiber phone line
From time to time when we answer an incoming call (which is routed through RingCentral to our fiber landline phone #) we cannot hear the caller. For a lengthy period of time, we just chalked it up to the caller probably using a mobile connection that was terrible. But it is happening a handful of times a day now, and it doesn't seem reasonable that this is the reason so often. We're puzzled since our landline is fiberoptic and we don't have this problem with outbound calls (which aren't routed through RingCentral). Ideas? Thanks!
1 Answer
· Write an Answer
mike avatar image
mike answered ·
Hi Lori,  My first guess is that it has nothing to do with the fiber line.  There could be something else going on and we'll be happy to look into this for you, but will need some details. Can you use the link below to open a case and tell us, time, dates, number call came from, number dialed, number call was routed to and be specific as to how it was routed, or forwarded, etc.
