arndt avatar image
arndt asked ·
Network: Recommend network switches without power saving modes?
I setup a Ringcentral  Asus RT-N66U router with QoS settings. The documentation suggest using a network switch without a "green" setting (power saving) mode which shuts down ports to save energy. I'm trying to find a 48-port Gigabit network switch but everything made today includes power savings. Are there any switches which are 48 port (or perhaps two 24-port switches) which would allow me to disable power saving modes?
bjsvec avatar image
bjsvec answered ·
I know you can disable power saving in Cisco SF and SG300 series. They are decent SMB switches.
john-tran avatar image
john-tran answered ·
Deploying switches with power saving mode features, or 'green' setting, is fine ...just long as it is a 'manageable' type of switch.  That is it will allow the Admin to log in to make changes and/or configure the feature settings.  You can then just disable the 'green' feature.
As for what may be some viable brands... Netgear and HP ProCurve's are also common options.
arndt avatar image
arndt answered ·
I've had others recommend the Pro Curve as well. So I assume I'll be able to switch off power savings then so long as it's managed. Is there a particular model number you'd recommended? I need at least 48 ports.
Hi Arndt.  Personally I like the ProCurve line also for a small/mid-sized office environment. They are slightly pricier than the other options, but are dependable and perform well.  As for a particular model, I think it's best to speak to reseller or we can get you in contact with one of our VARs.  Prices normally range from around $500 to $2500 (if not more) depending on what features you want (or don't care for).
Here's a good reference to what models are available and their prices.  You can filter further by feature.
https://www.cdw.com/shop/search/Networking-Products/Ethernet-Switches/Fixed-Managed-Switches/result....
arndt avatar image
arndt answered ·
https://www.cdw.com/shop/products/HP-1910-48-48-Port-Fast-Ethernet-Switch/3188806.aspx?enkwrd=&p...
This one is in my budget. Is there any reason I shouldn't get this model?
1 comment Share
Yes, this model perfectly fine... if you don't care for PoE (power over Ethernet) and/or ability for 1Gbps port speeds.
1 Like 1 · ·
