ted-larsen avatar image
ted-larsen asked ·
Do calls forwarded to cell phone NOT using RCApp get charged international minutes if cell phone is out of the country?
We have a user that wants calls forwarded to his personal cell phone.  He does not use the RCApp on his phone, nor does he want to.   This phone was purchased overseas and the account is international.   If he forwards calls to this cell phone while he is overseas,  does the  call use RC international minutes for the call or is it all charged based on the cell account at that point?  Does RC "hand off" the call when setup as a mobile number in his extension?
1 Answer
· Write an Answer
kim avatar image
kim answered ·
Example: U.S. Account
If a user has their extension forwarded to their personal cell phone, which is a Mexico base cell, then yes the call is forwarded to their cell phone carrier and there will be an international charge to the account.
If he answers the call via the RingCentral cell phone app over wifi then there will not be an international charge.
5 comments Share
Thanks Kim.  Just to clarify, the international charge is on their cell account, but does NOT use RingCentral international calling credits, correct?
0 Likes 0 · ·
Your RingCentral account will be charged an international charge because your RC account picked up the call and transferred/forwarded it to the international number.
0 Likes 0 · ·
Ok.  Thanks for the clarification. So there is no way to have a personal cell number inside the RingCentral system and not use International call credits if the caller/callee is outside the states, correct?
0 Likes 0 · ·
"..there is no way to have a personal cell number inside the RingCentral system and not use International call credits if the caller/callee  user's forwarded number is outside the states..."
correct
1 Like 1 · ·
Excellent, thank you!
0 Likes 0 · ·
