vacuum-store avatar image
vacuum-store asked ·
My incoming calls forwarded to 4 phones sequentially. Does Audio while connecting restart each time the call forwards to the next phone?
I have my incoming calls forwarded to 4 phones simultaneously. My question is does the Audio while connecting message restart each time the call is forwarded to the next phone?
bjsvec avatar image
bjsvec answered ·
I don't think so, but it should be quite easy to try yourself and find out :)
mike avatar image
mike answered ·
As Brandon said... it shouldn't but it's always a good idea to call the number, test the extensions/forwarding to make sure you are getting the expected behavior.
