james-veal avatar image
james-veal asked ·
Problem transferring calls from within federated accounts - MAJOR ISSUE
Problem with transferring calls from within federated accounts
james-veal answered ·
Hi Sadeet, Ive been working with our TAM and we have determined exactly what the issue is. Hopefully Tier 3 is able to find or fix the bug. Thank you for your reply.
saadet.swift avatar image
saadet.swift answered ·
Hey James, I see that you have a case open with us regarding this, which is the best course of action. Situations like this often require live troubleshooting.
