tim-doriot10129 avatar image
tim-doriot10129 asked ·
transferred calls going straight to speaker phone
when a call is transferred to one of our extensions, we pick the handset up to answer the call and the call is automatically on the speaker phone. Can this be shut off?
danno147 avatar image
danno147 answered ·
What is the make and model of the desk set?
tim-doriot10129 answered ·
we have the VVX 310
Polycom
danno147 answered ·
The setting is called auto answer.  You'll need to access the web config to turn it off:  Preferences => Additional Preferences => Auto Answer.
2 comments Share
You might also be able to to do via the phone.
On the phone, press Menu > Settings > Basic > Preferences > Auto Answer > Auto Answer SIP Calls.
Should be NO.
0 Likes 0 · ·
FYI, since you are reporting this is only happening on transferred calls, the web config has more options than the preference settings on the phone.
0 Likes 0 · ·
