jeri-fritz avatar image
jeri-fritz asked ·
Some calls and messages come through, others do not
Some voicemails and text messages do not ever show up in the ring central app. The only way we know that we are receiving those voicemails and texts is because we see them in our confirmation email from RingCentral. Could someone explain why this is occurring? There is only 1 number set up to receive the calls and messages. Thanks.
1 Answer
· Write an Answer
saadetswift16514 avatar image
saadetswift16514 answered ·
Hey Jeri,
I see that you have an open case with us right now, which is good! Things like this require quite a bit of back and forth in order to investigate. I checked your case and the technician gave you a call this morning and left a message. When you're able, give them a call back so we can take a look and help you out!
