dan-carmody avatar image
dan-carmody asked ·
How do I increase the ring duration and volume for incoming calls when already on a call?
How do I increase the ring duration and volume for incoming calls when already on a call?  Second calls do not ring but line indicator light illuminates then goes out.  We use Polycom VVX400 and Polycom VVX411 phones.
1 Answer
· Write an Answer
saadetswift16514 avatar image
saadetswift16514 answered ·
Hi Dan, the ring duration is dependent upon your settings under Call Handling & Forwarding
At this time, you cannot adjust the volume of the Call Waiting notification
