Heather Curtis avatar image
Heather Curtis asked ·
Audio sound on shared recorded video lowered when sharing screen
I can play a video on my desktop and the volume is perfect. However, when I share my screen and continue (or start) playing the same video in the same player, the audio automatically lowers to being nearly inaudible for the participants. This began with the last version upgrade. I've tried changing the audio source in RingCentral Meetings to no avail. What is going on here? Solutions?
General Topic
1 Answer
· Write an Answer
mona-graoui7095 avatar image
mona-graoui7095 answered ·
Hello Heather,
If you are using the meetings application on a Windows computer there is a Windows settings that automatically adjusts the volume of different sounds when you are on a call on the device in question. The meetings application falls under the list of apps that can adjust the volume and by default most Windows computers are set to reduce that volume by 50-80% depending on the settings.
To disable the setting you will want to right click over the volume icon in your icon dashboard and there should be an option to open up "Sounds". Once you are in the sounds menu you will want to go to the Communications tab and in there you will want to set the option to Do nothing and that will prevent the Meetings and also RingCentral Phone for desktop applications from automatically adjusting the volume of your other applications whenever you are on a call or screen share.
Let us know if you have any other questions or concerns about the audio settings!
4 comments
Mona, is there a way for the Phone app to also do this?  It doesn't work for me.  I'm on Windows 10.  I've used other phone apps that have this feature.
0 Likes 0 ·
Hi Paul,
Can you provide some more details? When are you experiencing lower audio sound within the RC softphone app?
0 Likes 0 ·
I want the phone app to turn off the sound for other apps when I answer a call on my computer.  That's what the above pic is for.  So if I'm listening to music via Groove or Media Player and I answer the phone, the music should be muted or turned down according to the settings in Sound like above.
0 Likes 0 ·
Oh, okay. Mona was referring to known limitation with the volume of the RingCentral phone app once you share your screen in RingCentral Meetings-- the volume was automatically, and incorrectly, lowering. The situation you're describing is not currently possible. Please vote on this product idea if you would like to see it.
0 Likes 0 ·
Work together.
From anywhere.
and phone - all in one app.
Get the new RingCentral app
