Larry Olson avatar image
Larry Olson asked asya-yakobson commented
How to turn off Ring Out and Turn on Direct
I am in outgoing calls on my computer app. Recently the app switched on the RingOut feature auto magically. I go in to the setting to direct dial and that feature is no longer there. How can I get it back?
ringcentral app
1 |3000
Larry Olson answered
I am on 10.1.2  I log in using my email which is linked to my direct number.
1 |3000
saadetswift16514 avatar image
saadetswift16514 answered
Hmm....what happens when you log in with your direct number?
1 |3000
From the admin screen I had to deactivate the account and reactivate the account. Now it works!
1 |3000
Weird! It must have gotten stuck on the back end or something. Glad it's working now!
1 |3000
khakh5403 avatar image
khakh5403 answered Larry Olson commented
this has happened to 3 different users for us. Might be worth looking into as we haven't found a resolution yet.
2 comments
1 |3000
saadetswift16514 avatar image saadetswift16514 commented ·
Hey KHAKH, please open a support ticket so we can gather debug logs :)
0 Likes 0 ·
Larry Olson avatar image Larry Olson commented ·
This happened to us and we had to reinstall RC on the computer that had the problem and the problem went away.
0 Likes 0 ·
asya-yakobson avatar image
asya-yakobson answered asya-yakobson commented
Any update on this? The same issue
2 comments
1 |3000
mary-community-moderator avatar image mary-community-moderator ♦♦ commented ·
HI Asya,
Are you logging in to a new device?
0 Likes 0 ·
asya-yakobson avatar image asya-yakobson commented ·
no
0 Likes 0 ·
james-temple avatar image
james-temple answered mary-community-moderator commented
Also having same issue, some devices using the same line can switch, others cannot
1 comment
1 |3000
Hi James,
Please make sure that on the web portal, there are no old devices authorized to login with the specific line. You need to deauthorize it first and logout/login on the app.
0 Likes 0 ·
Hey l.olson,
What version of the softphone are you on? How do you log into your extension? With a direct number or the main company number + your extension?
1 |3000
Work together.
From anywhere.
and phone - all in one app.
Get the new RingCentral app
