hebw-reception10611 avatar image
hebw-reception10611 asked ·
Incoming calls hear dead air
When an incoming caller calls our main line they hear dead air before receptionist answers. How can I set it up so they hear the phone ringing before the receptionist answers? When they just hear dead air they get confused and hang up.
1 Answer
· Write an Answer
J.B. Ferguson avatar image
J.B. Ferguson answered ·
Make certain that you enable the Audio While Connecting property on the main number/extension. You can also do this for any extension in your system. You get to that property by going to the Administrative Web Portal, then Screening, Greeting & Hold Music then User Hours and select the Audio While Connecting property. You can choose RingTones or music options.
