erica10678 avatar image
erica10678 asked ·
Ring Central Audio Issues
One of my reps is having audio issues during phone calls. The audio will drop however the phone call is still connected. We are based in the US. We have looked into her audio settings on her computer they are fine. She is the only rep to have this issue. She is using Windows 7 and she is using the current version 10.2.1.31914 on the desktop app
General Topic
lee2 avatar image
lee2 answered ·
Erica,
Try purging the data form the softphone. This has helped us in the past. It is in the softphone under Settings, Support, Purge data.
1 comment
Done. It happened again.
0 Likes 0 ·
bjsvec avatar image
bjsvec answered ·
Do you know if she hears the progress tone when this happens?
Have you looked at the QOS report to see if there is any clue on these calls?
2 comments
It does not make any noise. I checked the QOS and I see she has an issue from Server to Client.
0 Likes 0 ·
So that probably rules out the soft phone and desktop environment itself and points to a network issue of some sort.
What kind of firewall do you use and do you manage it?
0 Likes 0 ·
Work together.
From anywhere.
and phone - all in one app.
Get the new RingCentral app
