anderson12345 avatar image
anderson12345 asked jake-baldwin commented
virtual background in RingCentral Meetings
I'd like to make a feature request for the virtual backgrounds capability for RingCentral Meetings. It's been available on Zoom for several versions now.
Thanks!
meetings
jessica-community-moderator avatar image
jessica-community-moderator answered
Hi ANDERSON,
The virtual background capability is available in RC Meetings! For more information and instructions, check out this KB article.
anderson12345 answered
You're absolutely right!  Just needed to enable the feature, thank you!
bellatra-usa-llc avatar image
bellatra-usa-llc answered mary-community-moderator commented
Does anyone know if this virtual background feature was disabled?  I am on the most current version and I do not see the option on the menu as Jessica outlined.
4 comments
THE PICTURE USED IN THE VIRTUAL BACKGROUND IS FLIPPED/REVERSED; HOW CAN THAT BE CORRECTED?
1 Like 1 ·
This feature is off by default. Account Administrators can enable this feature account-wide and for Users. Account Administrators can go to Meetings > Meetings Settings > In Meeting (Advanced) and enable Virtual background.
If you want to use this feature, make sure this feature is on in your online account before a meeting. In your online account, click Settings > Meetings > toggle switch on the In Meeting (Advanced) section to enable Virtual background.
Once an option is enabled, Hosts and Participants can find the additional Video Background settings in the Meetings for Desktop.
0 Likes 0 ·
Thank you.  Got it! :)
-Chris
0 Likes 0 ·
Hello Patrick!
The virtual background flips once it is added. If you are going to add a background with words on it, I suggest for you to flip it first by editing the picture before uploading it.
Thanks!
0 Likes 0 ·
ben-camper avatar image
ben-camper answered
I am not seeing the option to enable virtual background via the Mac RC Meeting application. Is it avail for Macs?
mary-community-moderator avatar image
mary-community-moderator answered
Hi Ben!
Yes, it is also available on Mac. Make sure that your app is updated. Go to Settings > Virtual Background.
Let me know if you have further questions.
ben-camper answered
I do not see it in Meetings>Settings>Video (attached).
You are currently on Video Settings. Next to Video settings, you will see Virtual Background. Please check these icons.
ben-camper answered susan-bedsaul12117 commented
Hmm, I dont have that....perhaps I need to enable it at Admin level?
8 comments
Also,Setting the the green background is frustrating. Please remove that requirement
1 Like 1 ·
Beyond frustrating
1 Like 1 ·
Agreed. Why is it that RC requires a solid color background when Zoom doesn't if you're using their technology?
1 Like 1 ·
Agreed. I can use virtual background perfectly fine on zoom without the green screen requirement, but I can't on RingCentra....With majority working from home now, we need this feature for all, and I hope Ringcentral gets to upgrade their technology to remove the green screen requirement, and make it easy for folks to use this feature.
1 Like 1 ·
When will the green screen requirement be removed from Ring Central -- having to use green screen makes virtual backgrounds useless for home workers.
1 Like 1 ·
Show more comments
holly-pena avatar image
holly-pena answered mary-community-moderator commented
As Admin, I have turned on Virtual Background in the admin portal and also doublechecked each user where Virtual Background is toggled on.  On my own portal though, I still don't see Virtual Background in order to add one.
3 comments
Hi Holly!
Have you checked on your Meetings App if Virtual Background is already one of the settings?
0 Likes 0 ·
I think I had more than one App on my laptop, but now I have only one, and I do see the Virtual Background setting. However, in trying to delete what I didn't need, I also deleted the Green Background that I downloaded somehow earlier today.  Now I can't find it.  Where do I find it so that the Virtual Background will work?
0 Likes 0 ·
Try to check on your computer's downloaded files.
0 Likes 0 ·
rique10966 avatar image
rique10966 answered maria-bee commented
Jessica, it's kind of misleading to say that RC Meetings has the same virtual background feature which Zoom has. RC Meetings requires a physical green screen in order to use the feature. Zoom installs a plug-in which disables the requirement so a physical green screen is not needed with Zoom. And if you don't have the green screen with RC, the experience is awful (flashing and strobing - it is worthless). So I respectfully disagree with the statement that RC Meetings has the feature. For most users, it is not practical - and with everyone working from home now, it's actually necessary. At our company, we really hope you escalate the priority of enabling it fully. Thanks.
12 comments
I agree with Rique.
And I even would vote not for a virtual background from a picture - but if there would be a way to just blur the background (like Jitsi does it, there is even code for that on  https://gitlab.talview.com/meet/lib-jitsi-meet-v1/commit/fd74ccc526c9859d3566abdde2522035230f77bd) that would be perfect and sufficient. Thanks
1 Like 1 ·
It's useless for me as well. Please remove the requirement for having a green screen.
1 Like 1 ·
Ditto. This is all I need to use Zoom for meetings and not RC. Why can't you get to feature parity with Zoom in the middle of a pandemic????
1 Like 1 ·
Zoom also allows video for the background, which RC apparently does not. (unless that's a setting somewhere).
1 Like 1 ·
Yes, a blur background feature should be a priority in these times. Please make it so. I've already switched to Zoom for this in several meetings, but since our company has 200 people heavily invested in using RC, we need that change here.
1 Like 1 ·
Show more comments
Work together.
From anywhere.
and phone - all in one app.
Get the new RingCentral app
