janielle2936 avatar image
janielle2936 asked benjamin-dean answered
REST API Ringout results - is it possible to tell if the recipient never answered or if the call went to voicemail?
Hi
I've implemented RingOut using the REST API and it's working as expected. I have also set up a webhook notification, which is also working.
I'd like to know if it's possible to tell if the recipient (the to number) never answered or the call went to voice mail?
I don't see anything that indicates this in the call log or in the notification payload
rest apiringout
benjamin-dean avatar image
Have you tried setting the 'view=Detailed' query parameter for your GET request to /call-log to view the information about each leg of a call and the callStatus?  https://developers.ringcentral.com/api-docs/latest/index.html#!#RefExtensionCallLog.html
Another option would be to create a Push Notification (Subscription or Webhook) event consumer to be notified of presence events for extensions you wish to monitor.  https://developers.ringcentral.com/api-docs/latest/index.html#!#RefNotifications.html
janielle2936 answered
Yes, I have viewed the call logs with view=Detailed and I see nothing that indicates that the recipient didn't answer (or it went to voicemail)
As mentioned in my question I have webhook for notifications and there is nothing useful there either.
Could you provide the code you're using to create the webhooks and the filters you're using please? Also, if you could provide some example of the webhook events you're receiving, this might help to drill down into what is blocking you from being able to achieve your goal.
Sorry for only getting back to you now.
This is the JSON I POST to the subscription end point,
"eventFilters": [
"/restapi/v1.0/account/~/extension/~/presence?detailedTelephonyState=true&sipData=true",
"/restapi/v1.0/account/~/extension/~/presence/line/presence"
"deliveryMode": {
"transportType": "WebHook",
"address": "http://ringcentral.somedomain.io/v1/rpc/call/webhook"
This is for a ringout type call, all I can tell is that the calling side answered, there is no mention of the other party's status etc.
Here is what I see in the webhook event log.
{'json.data': {'body': {'activeCalls': [{'id': '', 'sessionId': '14424925004', 'from': '+34343434', 'telephonyStatus': 'Ringing', 'to': '+121212', 'sipData': {'localUri': 'sip:+34343434@ringcentral.com', 'remoteUri': 'sip:+121212@ringcentral.com'}, 'direction': 'Outbound'}], 'pickUpCallsOnHold': False, 'allowSeeMyPresence': True, 'sequence': 23753, 'telephonyStatus': 'Ringing', 'ringOnMonitoredCall': False, 'extensionId': 136908004, 'dndStatus': 'TakeAllCalls', 'userStatus': 'Available', 'presenceStatus': 'Available'}, 'uuid': '043d2818-7175-4dab-84b1-8aef485df15b', 'timestamp': '2016-08-30T15:02:39.437Z', 'subscriptionId': 'd424d24c-4104-4223-ad60-da3ebe40b1cf', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true'}}
/* Caller Answers his phone */
{'json.data': {'body': {'activeCalls': [{'id': 'da47a24af2f44ef4b12dbc0cd0abcea6', 'sessionId': '14424925004', 'from': '+34343434', 'telephonyStatus': 'CallConnected', 'to': '+121212', 'sipData': {'remoteUri': 'sip:+121212@ringcentral.com', 'fromTag': '10.28.20.109-5070-7d73312c2f8841', 'toTag': 'gK029fd65d', 'localUri': 'sip:+34343434@ringcentral.com'}, 'direction': 'Outbound'}], 'pickUpCallsOnHold': False, 'allowSeeMyPresence': True, 'sequence': 23755, 'telephonyStatus': 'CallConnected', 'ringOnMonitoredCall': False, 'extensionId': 136908004, 'dndStatus': 'TakeAllCalls', 'userStatus': 'Available', 'presenceStatus': 'Busy'}, 'uuid': '5ace2bdf-690a-4f44-bae3-fd98c0e075ce', 'timestamp': '2016-08-30T15:02:49.089Z', 'subscriptionId': 'd424d24c-4104-4223-ad60-da3ebe40b1cf', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true'}}
/* Call Ends */
{'json.data': {'body': {'userStatus': 'Available', 'pickUpCallsOnHold': False, 'telephonyStatus': 'NoCall', 'ringOnMonitoredCall': False, 'extensionId': 136908004, 'dndStatus': 'TakeAllCalls', 'allowSeeMyPresence': True, 'presenceStatus': 'Available'}, 'uuid': 'f663e0a4-b8ef-4dcb-8c0a-0e266cc5eae6', 'timestamp': '2016-08-30T15:03:35.347Z', 'subscriptionId': 'd424d24c-4104-4223-ad60-da3ebe40b1cf', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true'}}
The data you've provided has a 'telephonyStatus' property which indicates what happens with a call.
Have you tried generating the two use cases you've provided in your original question (Missed Call, and VoiceMail) to see what the result is in the 'telephonyStatus' property?
yes I have, it says the same thing for both:
Could you provide the full event stream (as you did earlier) for:
1. A missed call
2. A voicemail call
Here you go.
Missed Call
{'json.data': {'timestamp': '2016-08-31T15:42:21.555Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': '6effe768-758c-407f-a7ef-0ea70bcbf2fa', 'body': {'telephonyStatus': 'Ringing', 'allowSeeMyPresence': True, 'dndStatus': 'TakeAllCalls', 'activeCalls': [{'telephonyStatus': 'Ringing', 'sipData': {'localUri': 'sip:+2222222@ringcentral.com', 'remoteUri': 'sip:+1111111@ringcentral.com'}, 'direction': 'Outbound', 'id': '', 'sessionId': '14430984004', 'to': '+1111111', 'from': '+2222222'}], 'sequence': 27266, 'extensionId': 136908004, 'pickUpCallsOnHold': False, 'userStatus': 'Available', 'presenceStatus': 'Available', 'ringOnMonitoredCall': False}}}
{'json.data': {'timestamp': '2016-08-31T15:42:31.644Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': 'b32ce8c8-35f1-419c-8740-73819912635f', 'body': {'telephonyStatus': 'CallConnected', 'allowSeeMyPresence': True, 'dndStatus': 'TakeAllCalls', 'activeCalls': [{'telephonyStatus': 'CallConnected', 'sipData': {'localUri': 'sip:+2222222@ringcentral.com', 'fromTag': '10.28.20.109-5070-5bdc1b99d6c447', 'remoteUri': 'sip:+1111111@ringcentral.com', 'toTag': 'gK02f952af'}, 'direction': 'Outbound', 'id': '89acdd571ee642d0943324250e00d3b4', 'sessionId': '14430984004', 'to': '+1111111', 'from': '+2222222'}], 'sequence': 27268, 'extensionId': 136908004, 'pickUpCallsOnHold': False, 'userStatus': 'Available', 'presenceStatus': 'Busy', 'ringOnMonitoredCall': False}}} {'json.data': {'timestamp': '2016-08-31T15:42:49.205Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': '196b281a-51ca-42bd-8359-da130cb249b0', 'body': {'telephonyStatus': 'NoCall', 'dndStatus': 'TakeAllCalls', 'allowSeeMyPresence': True, 'userStatus': 'Available', 'pickUpCallsOnHold': False, 'extensionId': 136908004, 'presenceStatus': 'Available', 'ringOnMonitoredCall': False}}}
Voicemail
{'json.data': {'timestamp': '2016-08-31T15:40:29.627Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': 'c3c98916-5c16-4a83-b757-54d592deb1fa', 'body': {'telephonyStatus': 'Ringing', 'allowSeeMyPresence': True, 'dndStatus': 'TakeAllCalls', 'activeCalls': [{'telephonyStatus': 'Ringing', 'sipData': {'localUri': 'sip:+2222222@ringcentral.com', 'remoteUri': 'sip:+11111111@ringcentral.com'}, 'direction': 'Outbound', 'id': '', 'sessionId': '14430974004', 'to': '+11111111', 'from': '+2222222'}], 'sequence': 27263, 'extensionId': 136908004, 'pickUpCallsOnHold': False, 'userStatus': 'Available', 'presenceStatus': 'Available', 'ringOnMonitoredCall': False}}}    {'json.data': {'timestamp': '2016-08-31T15:40:42.548Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': '3f66c368-b673-4455-8250-b49f0a5e0325', 'body': {'telephonyStatus': 'CallConnected', 'allowSeeMyPresence': True, 'dndStatus': 'TakeAllCalls', 'activeCalls': [{'telephonyStatus': 'CallConnected', 'sipData': {'localUri': 'sip:+2222222@ringcentral.com', 'fromTag': '10.28.20.110-5070-aaf99dee0c7d4a', 'remoteUri': 'sip:+11111111@ringcentral.com', 'toTag': 'gK02f8cf47'}, 'direction': 'Outbound', 'id': 'c4833d50e5cf4d50b93a2da4a8d79ae1', 'sessionId': '14430974004', 'to': '+11111111', 'from': '+2222222'}], 'sequence': 27264, 'extensionId': 136908004, 'pickUpCallsOnHold': False, 'userStatus': 'Available', 'presenceStatus': 'Busy', 'ringOnMonitoredCall': False}}}    {'json.data': {'timestamp': '2016-08-31T15:41:11.423Z', 'event': '/restapi/v1.0/account/136908004/extension/136908004/presence?detailedTelephonyState=true&sipData=true', 'subscriptionId': 'e36f3168-0c5e-4ff7-b343-b643d80fd1cd', 'uuid': '352d3619-5416-4f0d-b124-e781ed4d7528', 'body': {'telephonyStatus': 'NoCall', 'dndStatus': 'TakeAllCalls', 'allowSeeMyPresence': True, 'userStatus': 'Available', 'pickUpCallsOnHold': False, 'extensionId': 136908004, 'presenceStatus': 'Available', 'ringOnMonitoredCall': False}}}
So your presence events for both types have a "NoCall" telephonyStatus at the end.
When your application sees that NoCall event (which means the end of a call), then you should capture the 'sessionId' for that call, and then you can do a lookup in the Call Log API for that extension and filter by sessionId (Call Log Record) === sessionId (presenceEvent). Then you can use the 'result' property of the Call Log record to provide you the information you require.
Does this answer your question?
Hi Benjamin,
Thanks for that. I did as you said, I queried the call log for the two session id's above (the one for the voice mail and the one for the missed call) and for both it returns:
"result": "Call connected",
Developer sandbox tools
