Julio Toledo avatar image
Julio Toledo asked Julio Toledo answered
Switching to -F/--form option for posting multipart/mixed forms?
My front-end development framework's cURL implementation requires all curl options be entered as raw text strings (text/plain). This is causing me all sorts of headaches with such things as posting multipart/mixed forms (i.e. FaxOut API requests).
For example, this works perfectly for me in Shell terminal but not in my front-end environment:
curl -X POST "https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/fax"; --header "Content-Type: multipart/mixed; boundary=Boundary_1_14413901_1361871080888" --header "Accept: application/json" --header "Authorization: Bearer {
                 {access_token}}" -d "--Boundary_1_14413901_1361871080888
  \"to\":[{\"phoneNumber\":\"18005630003\"}],
  \"faxResolution\":\"High\",
  \"sendTime\":\"2013-02-26T09:31:20.882Z\"
Content-Type: text/plain
Hello, World!
--Boundary_1_14413901_1361871080888--"
When I try the same command from my front-end I get:
{  "message" : "Bad Request",
  "errors" : [ ]
The cURL http scripting docs recommend using "--form" commands for RFC1867 posting. If correct, can you provide some working examples for Faxing and MMS of how boundaries and content-types would be specified when using "-F" options?
P.S. Any other solution or workaround would be welcomed.
errors
1 |3000
ak avatar image
ak answered
You could use the -F option to add each section of the multipart that you would want to POST. I did find something which might be helpful :
https://ec.haxx.se/http-multipart.html
Let us know if this helps.
1 |3000
Julio Toledo answered ak commented
Hi AK,
Thanks for your reply, your multipart form posts curl reference was somewhat helpful in that it moved me on to a different error response :|
So, I reconstructed my request as follows:
curl -X POST https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/fax"  --header "Accept: application/json"   --header "Authorization: Bearer {
                 {my access token}}"   -F to=18005630003   --header "Content-Type: text/plain"   -F coverIndex=12  --header "Content-Type: text/plain"   -F faxResolution=High   --header "Content-Type: text/plain"   -F attachment=Hello, World!  --header "Content-Type: text/plain"
I did this in attempt to mimic the " Pattern 3 Request format: multipart/form-data" example in your API Reference. And now the response to my request is always:
  "message" : "Unsupported Media Type",
  "errors" : [ ]
Tried different kinds of syntax and adding/removing options. Still nothing.
1 comment
1 |3000
Could you try the below :
curl -i -X POST https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/fax"
--header "Authorization: Bearer { {my access token}}"
--header "Content-Type: multipart/mixed"
-F file=filename.txt"
-F body={\"to\":[{\"phoneNumber\":\"18005630003\"}],\"faxResolution\":\"High\,\"sendTime\":\"2013-02-26T09:31:20.882Z\};type=application/json"
0 Likes 0 ·
Hi AK,
I tried your code. Got yet another (different) error response:
{    "errorCode" : "InvalidContent",    "message" : "Unable to parse fax envelope",    "errors" : [ {      "errorCode" : "MSG-349",      "message" : "Unable to parse fax envelope"    } ]  }
I tried the -F options with and without leading/trailing quotes. I even tried breaking out the "type=applicaton/json" into a trailing -H option (i.e. -H "Content-Type: application/json"). Same error.
1 |3000
Tyler Liu avatar image
Tyler Liu answered ak commented
curl \
--header "Accept: application/json" \
--header "Authorization: Bearer <token>" \
-F "request=@request.json;type=application/json" \
-F "attachment=@hello.txt;type=text/plain" \
Content of request.json file:
 "to": [{ "phoneNumber": <fax receiver> }]
Content of hello.txt:
<Whatever text you want to send.>
You can also send pdf:
-F "attachment=@test.pdf;type=application/pdf"
1 comment
1 |3000
That Works. Awesome Tyler.
0 Likes 0 ·
Thanks Tyler. That worked like a charm! :)
Now I gotta try something similar with MMS. Do you know when the MMS endpoint will be available for testing in the Sandbox?
1 |3000
Oops! Spoke to soon. Now my attachments are not rendering.
" Your fax included the following file(s). Please check the file(s) that could not be rendered for errors or refer to our website for supported file types.
Name                                   Phone Number          Date and Time                      Result
                                            +1 (305) 4081720                                                  Failed
File Name
Result
attachmentContent        Not rendered"
It's as if the attachment were being truncated or the Content-Length was not being calculated.
Even the text/plain example fails with just the phrase "Hello, world!" Just fyi, I am encoding the pdfs using Base64 (RFC 4648 )
This is the result of my post request:
{    "uri" : "https://platform.ringcentral.com/restapi/v1.0/account/540887020/extension/540887020/message-store/765035724012",    "id" : 765035724012,    "to" : [ {      "phoneNumber" : "+13054081720",      "location" : "Miami, FL",      "messageStatus" : "Queued"    } ],    "type" : "Fax",    "creationTime" : "2017-03-30T21:46:29.000Z",    "readStatus" : "Unread",    "priority" : "Normal",    "attachments" : [ {      "id" : 765035724012,      "uri" : "https://media.ringcentral.com/restapi/v1.0/account/540887020/extension/540887020/message-store/765035724012/content/765035724012",      "type" : "RenderedDocument",      "contentType" : "application/pdf"    } ],    "direction" : "Outbound",    "availability" : "Alive",    "messageStatus" : "Queued",    "faxResolution" : "High",    "faxPageCount" : 0,    "lastModifiedTime" : "2017-03-30T21:46:29.833Z",    "coverIndex" : 12  }
And the response headers are:
HTTP/1.1 100 Continue    HTTP/1.1 200 OK  Server: nginx/1.10.2  Date: Thu, 30 Mar 2017 21:46:29 GMT  Content-Type: application/json; charset=UTF-8  Content-Length: 416  Connection: keep-alive  RCRequestId: 55130dfe-1592-11e7-a7ce-005056affef3  RoutingKey: SJC01P05PAS06  Content-Language: en-US  Vary: Accept-Encoding, User-Agent  Content-Encoding: gzip  X-Rate-Limit-Group: heavy  X-Rate-Limit-Limit: 20  X-Rate-Limit-Remaining: 19  X-Rate-Limit-Window: 60
1 |3000
Tyler Liu answered
I just tied sending a plain text file with "hello world" as content and succeeded.
1 |3000
Tyler Liu answered
Please don't encode it with Base64. Just send it as binary.
Please reply if you still cannot get it work.
1 |3000
Tyler Liu answered
Just sent a PDF file successfully using curl:
1 |3000
Hi Tyler,
Thanks for following up. I appreciate your assistance.
For security reasons, my development framework does not permit direct file access, therefore I cannot simply point a variable to a binary. I have to load the binary into a variable and then I can make curl requests with it. My choices for that are either Hex Encoding or Base64 Encoding.
Having said, I'd like to test a couple of debugging exercises:
  1. I will test sending a fax cover sheet with a fax cover message and no attachment. If a fax can go thru with no attachment, then the binary is the issue.
  2. I'm gonna set up "mock bin" to capture my request and see what's coming across to you when I post an attachment (text or pdf)
Hopefully I'll be able to figure out what's going on with my fax form, as I will need similar code for posting an MMS form.
1 |3000
Developer sandbox tools
