Alfredo Inostroza avatar image
Alfredo Inostroza asked ·
API Ring-Out using forwardingNumberId not working after Ring Central Phone App to Ring Central App transition?
Due to the retirement of the RingCentral Phone App next month, we're moving to the combined RingCentral app.
We have dialer software that calls the Ring-Out API endpoint. The FROM phone uses the forwardingNumberId . It's much faster than having the extension ring, on the order of seconds, which is a big deal when the same agents get incoming calls.
https://platform.devtest.ringcentral.com/restapi/v1.0/account/accountId/extension/extensionId/ring-out
I can't get the endpoint to dial my softphone no matter what I do.
It appears to me that the issue is around whether or not the soft phone registers itself as Used Phone in the RingCentral Phone System admin area. I noticed it was offline. I deregistered the old app. The new app didn't re-register it. I switched the extension to a hard phone, and the app didn't register as a new soft phone.
Am I missing something? Will I need to revert to using the from DID?
apiringoutunified app
· Write an Answer
