sally-vilberg avatar image
sally-vilberg asked mary-community-moderator commented
What's the best way for a remote worker to call different states using local numbers?
We are considering hiring a remote worker for recruiting purposes who will be in contact with people in Michigan and Florida. We find that people only answer local numbers so I'm wondering if there is way to set up a line that will let the caller ID look local without having to buy multiple digital lines and changing the ring-out number for each call?
ringout
1 comment
1 |3000
Hi Sally, there is no option to set up a single line to change local Caller ID depending on states. However, you don't need to buy multiple Digital Lines; purchasing a virtual number is cheaper. It can be used as a Caller ID as well.
0 Likes 0 ·
Work together.
From anywhere.
and phone - all in one app.
Get the new RingCentral app
