News & Announcements User Community Developer Community
Welcome to the RingCentral Community
Please note the community is currently under maintenance and is read-only.
Search
Make sure to review our Terms of Use and Community Guidelines.
Home » Developers
How many external numbers can I forward calls from an Extension?
Tags: call forwarding
Dec 23, 2021 at 11:47am   •   3 replies  •  0 likes
Scott Portis
From an extension, in the Call Forwarding and Voicemail | Work Hours rules, I am attempting to forward a call to multiple external "Numbers" (not "Coworkers"). I have it set to "Ring all at once" and have 5 numbers listed. These numbers are cell phones.
The recipients report that only two of them are getting the calls forwarded to them. 3 are not getting calls at all. Is there a limit set to external numbers to receive forwarded calls from a single extension? If so, what is that limit. Is this documented anywhere?
answered on Dec 29, 2021 at 8:40am
Thank you both. Will test via removal of the two that worked. Will also play with the number of rings for each remote number.
 0
answered on Dec 27, 2021 at 7:41pm
Please refer to the article here: https://support.ringcentral.com/article/Calls-Not-Forwarding-RingCentral-to-Third-party-Phone-Numbers.html
You should be able to forward calls to more than 3 numbers (do not know the exact limit) as well via Call Forwarding and answering rule settings.
If you still have issues , please reach out to RingCentral Tech Support team for these queries : https://support.ringcentral.com
 0
answered on Dec 27, 2021 at 8:20am
I don't know how many (there is no documentation, and the service web just lets you click to add more number), but there must be some limit. However, I don't think that it is 5 numbers. If you remove the 2 numbers which got the forwarded call, did the other 2 or 3 numbers got ringing?
 0
A new Community is coming to RingCentral!
Posts are currently read-only as we transition into our new platform.
We thank you for your patience
during this downtime.
Try Workflow Builder
Did you know you can easily automate tasks like responding to SMS, team messages, and more? Plus it's included with RingCentral Video and RingEX plans!
Try RingCentral Workflow Builder
PRODUCTS
RingEX
Message
Video
Phone
OPEN ECOSYSTEM
Developer Platform
APIs
Integrated Apps
App Gallery
Developer support
Games and rewards
RESOURCES
Resource center
Blog
Product Releases
Accessibility
QUICK LINKS
App Download
RingCentral App login
Admin Portal Login
Contact Sales
© 1999-2024 RingCentral, Inc. All rights reserved. Legal Privacy Notice Site Map Contact Us
