P70 Backup avatar image
P70 Backup asked Phong Vu answered
Pre-Recorded Audio Over RingOut Call
My app uses RingOut to place automated calls. In my use case, I never really expect the "caller" to pick up the phone. I would like the "callee" to be played some sort of pre-recorded audio message if the caller has not picked up their leg. Is this possible using RingCentral's API? I see that I can create "Greetings", but how can I append one of these to a RingOut request such that it plays on pickup?
ringcentral appringout
1 |3000
1 Answer
Phong Vu avatar image
Phong Vu answered
Unfortunately, this is not supported. The most you can handle is to prerecord a greeting/voicemail message and set it to the caller call handling.
1 |3000
Developer sandbox tools
