Auth Flow ERR_CONNECTION_REFUSED on localhost
  • 8 April 2020
  • 1113 views
Hi. I am trying to run the Authorization Flow demo.
After I enter my username and password, I get a connection refused error. The uri in the browser looks like the following:
http://localhost:5000/oauth2callback?code=U0pDMTFQM
with a long string for code.
Any hints as to where to go next?
Userlevel 1
Can you show how you implement your code? Take out sensitive information such as you app client id, secret etc.
I just copied the C# example from the ringcentral site. The only thing I changed was the Client ID and Secret:
using System.Linq;
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.AspNetCore.Http;
using Microsoft.Extensions.DependencyInjection;
using RingCentral;
using Newtonsoft.Json;
using Microsoft.Extensions.Hosting;
namespace RCAuthFlowV2
public class Startup
private const string RINGCENTRAL_CLIENT_ID = "XXXXXXXXXX";
private const string RINGCENTRAL_CLIENT_SECRET = "YYYYYYYYYYYYYYYYYYY";
private const string RINGCENTRAL_SERVER_URL = "https://platform.devtest.ringcentral.com";
private const string RINGCENTRAL_REDIRECT_URL = "http://localhost:5000/oauth2callback";
private const string SESSION_TOKEN_KEY = "rc-token";
public void ConfigureServices(IServiceCollection services)
services.AddMvc().AddSessionStateTempDataProvider();
services.AddSession();
private static string Html(string body)
return $@"<!doctype html><html><body>{body}</body></html>";
public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
if (env.IsDevelopment()) app.UseDeveloperExceptionPage();
app.UseSession();
app.Run(async (context) =>
var rc = new RestClient(RINGCENTRAL_CLIENT_ID, RINGCENTRAL_CLIENT_SECRET, RINGCENTRAL_SERVER_URL);
var tokenString = context.Session.GetString(SESSION_TOKEN_KEY);
if (tokenString != null)
rc.token = JsonConvert.DeserializeObject<TokenInfo>(tokenString);
else if (context.Request.Path != "/oauth2callback")
var oauthUri = rc.AuthorizeUri(RINGCENTRAL_REDIRECT_URL);
await context.Response.WriteAsync(
Html($"<h2>RingCentral Authorization Code Flow Authentication</h2><a href="{oauthUri}">Login RingCentral Account</a>"));
return;
switch (context.Request.Path)
case "/":
await context.Response.WriteAsync(Html(@"<b><a href=""/logout"">Logout</a></b>
<h2>Call APIs</h2>
<ul>
<li><a href=""/test?api=extension"" target=""_blank"">Read Extension Info</a></li>
<li><a href=""/test?api=extension-call-log"" target=""_blank"">Read Extension Call Log</a></li>
<li><a href=""/test?api=account-call-log"" target=""_blank"">Read Account Call Log</a></li>
</ul>"));
break;
case "/oauth2callback":
context.Request.Query.TryGetValue("code", out var codes);
var code = codes.First();
await rc.Authorize(code, RINGCENTRAL_REDIRECT_URL);
context.Session.SetString(SESSION_TOKEN_KEY, JsonConvert.SerializeObject(rc.token));
context.Response.Redirect("/");
break;
case "/test":
context.Request.Query.TryGetValue("api", out var apis);
var api = apis.First();
var result = "";
switch (api)
case "extension":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension");
break;
case "extension-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension/~/call-log");
break;
case "account-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/call-log");
break;
await context.Response.WriteAsync(Html($"<pre>{result}</pre>"));
break;
case "/logout":
await rc.Revoke();
context.Session.Remove(SESSION_TOKEN_KEY);
break;
default:
context.Response.StatusCode = 404;
break;
