I have at least 3 users now, for whom calls ring their iPhone very briefly, then immediately disconnect. Both queue calls and direct calls to their extension behave the same way. This is very frustrating.
Have you checked the number of rings under the Call Forwarding Settings? Check the KB article below for instructions.
Thanks for the suggestion. Yes, I have checked the number of rings. I have changed that setting, along with the "ring all at once" / "ring in order" setting under Call Handling. None of those seem to make any difference.
However, I should point out that the issue is intermittent. I have seen this user's phone drop several calls (from both call queues of which she is a member, and direct calls to her extension) in a row, then suddenly accept a call "properly", all without anyone making any changes.
Thanks for clarifying this. Since it is an intermittent behavior, please submit a ticket with Tech Support so they can check on it.
7 People are following this question.
and phone - all in one app.
Get the new RingCentral app
