Dear community,
I need to develop a server based webhook call monitoring application. Golang will be used as a progamming language. I did a research on available sdks and libraries for Golang and i like this one: https://github.com/ringcentral/ringcentral-go/blob/master/ringcentral.go although it is not mentioned as an official sdk on the https://developers.ringcentral.com/guide/sdks. Is it considered obsolete? If no, then why it is not on the sdk page? I need something well tested, reliable and simple. Or would you rater recommend to use one of the community provided SDK?
Thanks.
Best,
Nikolai
Best answer by Phong1426275020
View original
