iam trying to test sms call via code got this error
# POST BODY body = { "from": { "phoneNumber": "+1929415xxxx" }, "to": [ { "phoneNumber": "+1929378xxxx" } ], "text": "test api call", } rcsdk = SDK(RC_CLIENT_ID,RC_CLIENT_SECRET,RC_SERVER_URL) platform = rcsdk.platform() try: # Assuming platform.login() logs in using the token platform.login(jwt=jwt_token) # Assuming you have a 'body' variable defined elsewhere response = platform.post('/restapi/v1.0/account/~/extension/~/sms', body) data=json.loads(response.text()) print("Request successful.",data) # Check response status for success api_response_status = response.json().messageStatus if api_response_status == "Received" or "Queued": print('SMS sent successfully!',api_response_status) else: print(f'Failed to send SMS. Status: {response.json().messageStatus}') except Exception as e: print(f"Error occurred while processing token {e}") got this error:Error occurred while processing token The requested feature is not available then tried from api reference ui got this error { "errorCode": "FeatureNotAvailable", "message": "The requested feature is not available", "errors": [ { "errorCode": "MSG-242", "message": "The requested feature is not available" } ] } looked though few post here in many mention to check account type /restapi/v1.0/account/accountId/phone-number: { "uri":"https://platform.devtest.ringcentral.com/restapi/v1.0/account/338914004/phone-number/373220004" "id":373220004 "phoneNumber":"+1929415xxxx" "paymentType":"Local" "location":"New York City, NY" "type":"VoiceFax" "usageType":"MainCompanyNumber" "status":"Normal" "primary":false }
