Chrome extension does not stop ringing!!! Please Helps!!!
  • 27 March 2020
  • 674 views
Why does the ring central Chrome extension sometime just start ringing with ABSOLUTELY no way to end it. There is no call coming in so there is nothing for me to hang up on. It would just ring for ever if I didnt either sign out and sign back in or uninstall the chrome extension and then re install. Why is this happening??
Userlevel 2
Hi Spencer!
Please coordinate this with our Technical Support so that they can check what's the issue with it.
It is terribly annoying, you can't change the tone or volume either.
This "RingCentral for G-Suite" is a huge misnomer. We cannot even see our contacts in the app--and I mean all 3 or 4 or is it 5 now, versions of it.
