After the call is received by the end-user, their caller ID does not show the actual person that called but instead shows a call from our receptionist. This even happens with recorded calls making the call log and call recordings incredibly difficult to navigate and search. For an end-user to find a call that was patched through by reception, the user has to know the specific date and time and search that way; if they want to find the caller ID associated with the person that called, they have to reach out to IT to search on the admin end using reception's call log.
In addition, this have proved incredibly difficult for managing call recordings because we can't simply search by the number since the moment a call is transferred by reception, it gets marked as a recording between reception and the user.
With that, is there a way to set inbound caller IDs to appear for calls transferred by reception to users?
Thank you!
