danilo-meireles6216 avatar image
danilo-meireles6216 asked Tyler Liu answered
OAuth 2.0 Code flow - C#
Hello!
I have difficulty to start using RingCentral Api.
My application type is "Public" and my Platform Type is "Server/Web".
I am using C# to authorize but I got Bad Request and the following answser:
"error" : "unauthorized_client",
"error_description" : "Unauthorized for this grant type",
"errors" : [ {
"errorCode" : "OAU-251",
"message" : "Unauthorized for this grant type"
I saw that it is because my Platform Type (Server/Web) does not support password grant type and I need to use "OAuth 2.0 Code flow".
I tried to find an example using "OAuth 2.0 Code flow" in C# but did not find anything. Could you please give me an example that works for me?
Thank you very much!
getting started
1 |3000
1 Answer
Tyler Liu avatar image
Tyler Liu answered
Yes, here it is:  https://github.com/ringcentral/ringcentral-demos-oauth  There are C# samples.
1 |3000
Developer sandbox tools
