AuthorizeUri and also authentication did not so please help me
please check below code
class Program
var uri = new Uri(string.Format(" http://{0}:{1}";, Config.Instance.AppHost, Config.Instance.AppPort));
using (var host = new NancyHost(uri))
host.Start();
Console.WriteLine("Your application is running on " + uri);
Console.WriteLine("Press any [Enter] to close the host.");
Console.ReadLine();
public class DefaultModule : Nancy.NancyModule
private const string MyState = "United States";
// must be static. Because every time there is new request, a new instance of this class is created.
static SDK rcsdk = new SDK(Config.Instance.AppKey,
Config.Instance.AppSecret,
Config.Instance.ServerUrl,
"C# OAuth2 demo app", "1.0.0");
public DefaultModule()
var authorizeUri = rcsdk.Platform.AuthorizeUri(Config.Instance.RedirectUrl, MyState);
var template = File.ReadAllText("index.html");
Get["/"] = _ =>
var tokenJson = "";
var authData = rcsdk.Platform.Auth.GetData();
if (authData.ContainsKey("access_token") && authData["access_token"] != null)
tokenJson = JsonConvert.SerializeObject(authData, Formatting.Indented);
var page = Engine.Razor.RunCompile(template, "templateKey", null,
new { authorize_uri = authorizeUri, redirect_uri = Config.Instance.RedirectUrl, token_json = tokenJson });
return page;
Get["/callback"] = _ =>
var authCode = Request.Query.code.Value;
rcsdk.Platform.Authenticate(authCode, Config.Instance.RedirectUrl);
return ""; // js will close this window and reload parent window
class Config
private static Config instance = null;
private Config() { }
public static Config Instance
get
if (instance == null)
using (var sr = new StreamReader("config.json"))
var jsonData = sr.ReadToEnd();
instance = JsonConvert.DeserializeObject<Config>(jsonData);
return instance;
[JsonProperty("RC_APP_KEY")]
public string AppKey;
[JsonProperty("RC_APP_SECRET")]
public string AppSecret;
[JsonProperty("RC_APP_SERVER_URL")]
public string ServerUrl;
[JsonProperty("RC_APP_REDIRECT_URL")]
public string RedirectUrl;
[JsonProperty("MY_APP_HOST")]
public string AppHost;
[JsonProperty("MY_APP_PORT")]
public string AppPort;
[JsonProperty("UserName")]
public string UserName;
[JsonProperty("Password")]
public string Password;
[JsonProperty("Extension")]
public string Extension;
class Program
host.Start();
Console.ReadLine();
Get["/"] = _ =>
var tokenJson = "";
return page;
class Config
get
return instance;
