Hi, api wizards!
I've worked with OAuth2 to facilitate authentication with dozens of api's in PHP (ver 5.2 through 7.3), however, there seem to be some differences with how RingCentral uses OAuth and I'm struggling to get authentication to work.
- I can't seem to identify how to specify permissions. Normally they're expressly listed in the authorize call. Are they implied by the user credentials in this case or am I missing how to set that request?
- API docs give a longer than usual list of parameters as form data parameters but specify that the auth request is to be a GET action, no POST parameters allowed...so I'm confused by that.
- One of my attempts in Postman returned the message, "No redirect uri is registered for the client". Is there a place that the uri might be specified first (before the auth call, possibly in the app...sandbox in this case) and I'm missing it?
- Speaking of Postman, it would be much easier if someone had, or could share, the configuration in Postman for the auth leg. I'm sure the token request and refresh cycles won't be a problem from there...I just have to work out the auth leg and a Postman config would really simplify that...if so, THANK YOU!!!
Thanks in advance for all advice and/or help!
Best answer by Anirban2396911020
View original
