Why is the voicemail webhook not sent when receiving a voicemail?
  • 4 June 2021
  • 6 replies
  • 1125 views
Hi there,
We are encountering an issue with a mutual customer where the voicemail webhook is only being sent when the voicemail is read by the user, but not when the voicemail was received.
Any ideas?
We've also submitted a help support ticket but the turnaround time is extremely slow. We have mutual customers that are unhappy.
We are still seeing some issues with voicemails noted in the call logs that are 404s
For example, take a look at this call log entry - https://platform.ringcentral.com/restapi/v1.0/account/59721889/call-log/O5AL2qaQTawozUA?view=Detailed
This is the voicemail URL in one of the legs, and it does not exist - https://platform.ringcentral.com/restapi/v1.0/account/59721889/extension/59855527/message-store/1550344499004 . We get a " HTTP 404: CMN-102 - Resource for parameter [messageId] is not found" error.
The voicemail is in fact in a different extension - https://api.ringcentral.com/restapi/v1.0/account/59721889/extension/59721889/message-store/1550344499004
Can we get this escalated please so we can find a resolution?
Userlevel 1
Show me some code how you subscribe for voicemail notification.
BTW, you should read voicemail from the message-store, not from the call log.
var endpoint = '/restapi/v1.0/account/~/extension/~/message-store'
var params = {
      messageType: 'VoiceMail'
If you want to read voicemail using the call-log endpoint, you have to make a GET call to the message.uri to get the message metadata then parse the response to get the uri of the binary attachment.
https://platform.ringcentral.com/restapi/v1.0/account/xxxxxx/extension/yyyyyy/message-store/9152177004
  uri: 'https://platform.ringcentral.com/restapi/v1.0/account/xxxxxx/extension/yyyyyy/message-store/9152177004',
  to: [
      phoneNumber: '+1312982xxxx',
      extensionNumber: '101',
    phoneNumber: '+1650513xxxx',
  type: 'VoiceMail',
  creationTime: '2021-03-05T20:10:35.000Z',
  readStatus: 'Unread',
  priority: 'Normal',
  attachments: [
      uri: 'https://media.devtest.ringcentral.com/restapi/v1.0/account/xxxxxx/extension/yyyyyy/message-store/9152177004/content/9152177004',
      type: 'AudioRecording',
      contentType: 'audio/mpeg',
      vmDuration: 1
  direction: 'Inbound',
  availability: 'Alive',
  messageStatus: 'Received',
  lastModifiedTime: '2021-03-05T20:10:35.594Z',
  vmTranscriptionStatus: 'NotAvailable'
Here is the event we are subscribing to:
/restapi/v1.0/account/59721889/extension/59721889/voicemail
We notice that the voicemails webhook only get sent out to us after the user reads the voicemail (which is a few hours after the voicemail was recorded)
We have a backfill script that polls the call logs for missed calls, and in addition to that if there are calls that results in voicemails, we want to pull them into our system to log them.
Here is a sample call log:
  "uri": "https://platform.ringcentral.com/restapi/v1.0/account/377098040/call-log/B5TOIqqWARrHzUA?view=Detailed",
  "id": "B5TOIqqWARrHzUA",
  "sessionId": "91651935040",
  "startTime": "2021-04-02T16:22:36.750Z",
  "duration": 88,
  "type": "Voice",
  "direction": "Inbound",
  "action": "Phone Call",
  "result": "Voicemail",
  "to": {
    "phoneNumber": "+1888..."
  "from": {
    "name": "L...",
    "phoneNumber": "+1618...",
  "telephonySessionId": "s-ec6115b764294caf80078e7ecf4c1934",
  "transport": "PSTN",
  "lastModifiedTime": "2021-04-02T16:24:14.111Z",
  "billing": {
    "costIncluded": 0.059,
    "costPurchased": 0
  "legs": [
      "duration": 88,
      "type": "Voice",
      "to": {
      "from": {
        "name": "L...",
      "billing": {
        "costPurchased": 0
      "legType": "Accept",
      "master": true
      "startTime": "2021-04-02T16:22:36.766Z",
      "duration": 27,
      "type": "Voice",
      "result": "Accepted",
      "to": {
        "name": "IVR Menu 1001",
        "phoneNumber": "+1888",
        "extensionId": "386022040"
      "from": {
        "name": "L...",
      "extension": {
        "uri": "https://platform.ringcentral.com/restapi/v1.0/account/377098040/extension/386022040",
        "id": 386022040
      "reason": "Accepted",
      "reasonDescription": "The call connected to and was accepted by this number.",
      "legType": "Accept"
      "startTime": "2021-04-02T16:23:04.119Z",
      "duration": 61,
      "type": "Voice",
      "to": {
        "name": "Returns",
        "phoneNumber": "+1888...",
        "extensionId": "386009040"
      "from": {
        "name": "L...",
      "message": {
        "uri": "https://platform.ringcentral.com/restapi/v1.0/account/377098040/extension/386009040/message-store/1401140377040",
        "id": "1401140377040",
        "type": "VoiceMail"
      "extension": {
        "uri": "https://platform.ringcentral.com/restapi/v1.0/account/377098040/extension/386009040",
        "id": 386009040
      "legType": "Accept"
When I fetch the voicemail message, which is
it gives me a 404
This is because for some reason, the voicemail is actually in a different extension:
https://platform.ringcentral.com/restapi/v1.0/account/377098040/extension/377100040/message-store/1401140377040
So couple issues:
1. Why does the call log say the voicemail message is in one extension, but is actually in another?
2. Why does the voicemail webhook only get sent out after it was read even though it was received a few hours prior?
Userlevel 1
Hang on there. I just test /voicemail notification on Webhooks and observe the same issue as you reported. I will let the engineering team know to fix this asap.
Hi Phong - has this been resolved?
Userlevel 1
It is working as normal as I just run my test. Can you clear all active subscription (if any) and subscribe a new one, print out the re request id (from the headers) and the subscription id. I will ask the engineer to have a look at your subscription.
