Kyle Watson avatar image
Kyle Watson asked ·
turn off Remote Call hold monitoring on custom provisioned vvx 500
Long Story Short, we require a custom provision for our phones.
Everything works fine except for putting calls on hold. Previously, when a call was on hold, you would only know if you looked at your call presence (the white phone icon)
Now however with the custom provision, if a call is placed on hold, it immediately shows up as a prompt on all the other phones (as if an incoming phone call was happening)
Any one know the configuration necessary to turn this off in the xml configuration file?
I have tried:
call.hold.remoteNotification.enabled="0"
But this line gets removed on reboot.
kim avatar image
kim answered ·
Let me do some research in our Test Lab
Kyle Watson answered ·
I have 1 phone that is manually provisioned but I'm testing with other phones that use Ring Central's default provisioning ( https://pp.ringcentral.com/pp).
Maybe the cause is mixing the two? According to polycom they think it's a shared line feature that causes this.
http://community.polycom.com/t5/VoIP/turn-off-remote-hold-notification-on-vvx-500/td-p/74674
kim avatar image
kim answered ·
Setting conversation to private: what is the Serial Number + Phone Number of the device?
2 comments Share
I think I've got it figured out. The UC software on the phone that was having the issue was 5.2.2.0501 (I think anyway, i didn't write it down)
What's odd is, I tried to update the software from the web utility but it didn't work. I tried downgrading to a 4xxx version but it wouldn't downgrade. Finally, I REFORMATED the phone and installed the latest UC version and it is working correctly and no longer has the issues I described above.
0 Likes 0 · ·
OK.  Thank you for the update.  Glad you were able to resolve the issue :-)
0 Likes 0 · ·
