Jun 15, 2021 3:54 PM UTC
What's the best way for a remote worker to call different states using local numbers?
We are considering hiring a remote worker for recruiting purposes who will be in contact with people in Michigan and Florida. We find that people only answer local numbers so I'm wondering if there is way to set up a line that will let the caller ID look local without having to buy multiple digital lines and changing the ring-out number for each call?
    Jun 16, 2021 2:55 PM UTC
    Hi Sally, there is no option to set up a single line to change local Caller ID depending on states. However, you don't need to buy multiple Digital Lines; purchasing a virtual number is cheaper. It can be used as a Caller ID as well.
