BLF Not Populating with Contacts
  • 24 January 2022
  • 972 views
Hello,
The phone in question is the YeaLink T46S. Before I learned about the BLF fields, I populated contacts to 7 of the 10 buttons as a "Custom Key". Then when I learned about the Busy Lamp Fields under "presence", I set all 10 on my dekstop application, then my phone restarted and only the last three fields populated (the ones I had not previously set as a custom key).
I cannot figure out how or why, but the original 7 will not populate.
Userlevel 4
Badge
Hi @Zach Goforth, we're looking into this issue and will get back to you.
Userlevel 4
Badge
Please try the steps below,
First, reset your phone's local config (not factory reset).
Then set up the phone's user presence in the Admin Portal instead of the RingCentral App. Follow the process here.
