caller id and number called on inbound calls,caller ID and called number on inbound calls
  • 27 April 2021
  • 417 views
add both: caller id and number called on inbound calls for each user. Number called option is not working at this time
Can you add both, caller ID and called number on inbound calls in the same time?
Called number doesn't work at all at the moment
Userlevel 4
Badge
Hi Mike, for incoming calls, it can show only two options. Incoming Caller ID displays the phone number of the person calling and Called Number, which displays the phone number that the person dialed.You may submit a feature request if you want this to be available. You can submit it in our Ideas Portal at https://ideas.ringcentral.com/.
