Two-Step Verification / Multi-factor Authentication
  • 16 March 2021
  • 2228 views
Hi ,
Are there any plans to add Two-Step Verification / Multi-Factor Authentication via OTP (One Time Password) to the Admin Portal and user extensions? It's amazing this feature does not already exist.
Thanks!
Userlevel 4
Badge
Hi! Codes are still sent if you login to a new device so it will be recognized.
When you sign in with a new device, the Two step Verification get activates and ask the verification codes send to your registered email id as you can see below:
