Authorization Code Issue
  • 27 January 2020
  • 319 views
When i hit the below url https://platform.ringcentral.com/restapi/oauth/authorize?response_type=code&redirect_uri=https://myapp.example.com/oauth2Callback&client_id=avalidclientid&display=&prompt= then get the issue
{  "error" : "invalid_client",  "errors" : [ {    "errorCode" : "OAU-153",    "message" : "Invalid client: sM54NwmFSIK0wxKSo5SSFA",    "parameters" : [ {      "parameterName" : "client_id",      "parameterValue" : "sM54NwmFSIK0wxKSo5SSFA"    } ]  } ],  "error_description" : "Invalid client: sM54NwmFSIK0wxKSo5SSFA" }
Userlevel 2
Badge
Not sure how do you implement your app and where do you run your app. But it looks like the redirect_uri https://myapp.example.com/oauth2Callback is not valid.
If you run your app on a local machine, specify the redirect_uri e.g.
RINGCENTRAL_REDIRECT_URL= 'http://localhost:[PORT]/oauth2callback'
where, [PORT] is the port you are running your server app.
Remember to change the redirect_uri in your RingCentral app as well.
