Basic C# example not working.
  • 17 February 2022
  • 9 replies
  • 470 views
Hello, first time user here. I'm trying to test the most basic code sample for C# but it isn't working and it's throwing a very vague exception. Code and exception below. I replaced the sensitive variables with comments describing what they had been set to.
using System;
using System.Threading.Tasks;
using RingCentral;
using DotNetEnv;
namespace Call_Ringout
class Program
static RestClient restClient;
restClient = new RestClient(
/*Client ID*/,
/*Client Secret*/,
"https://platform.devtest.ringcentral.com");
restClient.Authorize(
/*Username*/,
/*Extension*/,
/*Password*/;
call_ringout().Wait();
static private async Task call_ringout()
var parameters = new MakeRingOutRequest();
parameters.from = new MakeRingOutCallerInfoRequestFrom
phoneNumber = /*From Number*/
parameters.to = new MakeRingOutCallerInfoRequestTo
phoneNumber = /*To Number*/
parameters.callerId = new MakeRingOutCallerInfoRequestTo
phoneNumber = /From Number/
parameters.country = new MakeRingOutCoutryInfo
id = "1"
parameters.playPrompt = false;
//var resp = await restClient.Restapi().Account().Extension().RingOut().Post(parameters);
//Console.WriteLine("Call Placed. Call status" + resp.status.callStatus);
var _1 = restClient.Restapi();
var _2 = _1.Account();
var _3 = _2.Extension();
var _4 = _3.RingOut();
try
var resp = await _4.Post(parameters);
catch(Exception e)
Console.WriteLine(e.InnerException);
Console.WriteLine(e.Message);
Console.WriteLine(e.ToString());
I broke up the line
Into its component parts to see where the problem is. It is in the last part, which is why I put the try block around it alone.
Here is the error I'm getting:
Object reference not set to an instance of an object.
System.NullReferenceException: Object reference not set to an instance of an object.
at RingCentral.RestClient.Request(HttpRequestMessage httpRequestMessage, Int32 retriedTimes, Nullable`1 cancellationToken)
at RingCentral.RestClient.Request(HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
at RingCentral.RestClient.Request[t](HttpMethod httpMethod, String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
at RingCentral.RestClient.Post[t](String endpoint, Object content, Object queryParams, Nullable`1 cancellationToken)
at RingCentral.Paths.Restapi.Account.Extension.RingOut.Index.Post(MakeRingOutRequest makeRingOutRequest, Nullable`1 cancellationToken)
at Call_Ringout.Program.call_ringout() in C:Userswscheffeysource
eposCall_RingoutCall_RingoutProgram.cs:line 55
C:Program Filesdotnetdotnet.exe (process 28572) exited with code 0.
To automatically close the console when debugging stops, enable Tools->Options->Debugging->Automatically close the console when debugging stops.
Press any key to close this window . . .
Any help greatly appreciated.
I am having the same issue when doing a calllog, has anybody found a solution to this ?
Userlevel 2
Badge
I don't see how you create the query params so I cannot say what could be wrong. But get the latest .NET SDK and try this code.
using System;
using System.IO;
using System.Collections.Generic;
using RingCentral;
using Newtonsoft.Json
namespace Read_User_CallLog
  class Program
      try
        DotEnv.Load();
        // Instantiate the SDK
                "RC_CLIENT_ID",
                "RC_CLIENT_SECRET",
                "RC_SERVER_URL");
        // Authenticate a user using a personal JWT token
        await restClient.Authorize( "RC_JWT" );
        await read_user_calllog();
      catch (Exception ex)
    * Read user call log between a period of time
    static private async Task read_user_calllog()
      try
        var queryParams = new ReadUserCallLogParameters();
        queryParams.dateFrom = "2024-01-01T00:00:00.000Z";
        queryParams.dateTo = "2024-01-31T23:59:59.009Z";
        queryParams.view = "Detailed";
        var resp = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
        foreach (CallLogRecord record in resp.records)
          Console.WriteLine(JsonConvert.SerializeObject(record, Formatting.Indented));
        Console.WriteLine("Cannot read user call log data. " + ex.Message);
using Newtonsoft.Json;
using RingCentral;
using System;
    class Program
        static async Task Main(string[] args)
            try
                RestClient restClient = new RestClient(
                    "<myclientid>",
                    "<mysecret>",
                    "https://dummy.com"
                // I have to use ConfigureAwait instead of wait cause it will
                //just never return with wait.
                restClient.Authorize("<MyJWT>").ConfigureAwait(false);
            try
Thank you for replying. My code was in a .net API. I changed it to a console app but still getting the same issue, any help would be welcome.
Userlevel 2
Badge
You declared the static RestClient restClient in your class, then you declare a local restClient????
                    "<myclientid>",
                    "<mysecret>",
                    "https://dummy.com"
Remove it!
                    "<myclientid>",
                    "<mysecret>",
                    "https://dummy.com"
I still get the same error message
class Program
    static RestClient restClient = new RestClient(
          "<myclientid>",
                    "<mysecret>",
                    "https://dummy.com"
        try
        try
Userlevel 2
Badge
It's not the same error. Before, the restClient was null.
What is the reason you call the authorize this way?
Try this to see if it helps
await restClient.Authorize("<MyJWT>"));
I changed everything to be await and I am now able to get records back, however it is only returning calls I have made. I am an admin on our account. Please help me with this.
 class Program
         "<myclientid>",
         "<mysecret>", true
         try
             await restClient.Authorize("<MyJWT>");
             var ringCallLogResponse = await read_user_calllog();
     static private async Task<CallLogResponse> read_user_calllog()
         CallLogResponse callLog = new CallLogResponse();
         try
             callLog = await restClient.Restapi().Account().Extension().CallLog().List(queryParams);
             foreach (CallLogRecord record in callLog.records)
         return callLog;
When I run it at https://developers.ringcentral.com/api-reference/Call-Log/readCompanyCallLog. I get back 99 pages with 100 records per page.
I removed the .Extension() and changed ReadUserCallLogParameters to ReadCompanyCallLogParameters and it works. Thank you for you help.
