Choosing right sdk or library for Golang
  • 8 August 2022
  • 309 views
Dear community,
I need to develop a server based webhook call monitoring application. Golang will be used as a progamming language. I did a research on available sdks and libraries for Golang and i like this one: https://github.com/ringcentral/ringcentral-go/blob/master/ringcentral.go although it is not mentioned as an official sdk on the https://developers.ringcentral.com/guide/sdks. Is it considered obsolete? If no, then why it is not on the sdk page? I need something well tested, reliable and simple. Or would you rater recommend to use one of the community provided SDK?
Thanks.
Best,
Nikolai
Userlevel 2
Badge
That Golang SDK is not a RingCentral official supported SDK and yes, it can be considered as obsolete because it is not updated nor maintained.
You can clone/fork and use this SDK developed by an ex-RingCentral expert. If you have questions, you can create issues directly to the owner repo.
Thanks for this one, Phong!
