having issue when trying to send sms using jwt token
  • 1 April 2024
  • 66 views
iam trying to test sms call via code got this error
# POST BODY
body = {
"from": {
"phoneNumber": "+1929415xxxx"
"to": [
"phoneNumber": "+1929378xxxx"
"text": "test api call",
rcsdk = SDK(RC_CLIENT_ID,RC_CLIENT_SECRET,RC_SERVER_URL)
platform = rcsdk.platform()
try:
# Assuming platform.login() logs in using the token
platform.login(jwt=jwt_token)
# Assuming you have a 'body' variable defined elsewhere
response = platform.post('/restapi/v1.0/account/~/extension/~/sms', body)
data=json.loads(response.text())
print("Request successful.",data)
# Check response status for success
api_response_status = response.json().messageStatus
if api_response_status == "Received" or "Queued":
print('SMS sent successfully!',api_response_status)
else:
print(f'Failed to send SMS. Status: {response.json().messageStatus}')
except Exception as e:
print(f"Error occurred while processing token {e}")
got this error:Error occurred while processing token The requested feature is not available
then tried from api reference ui
got this error
{ "errorCode": "FeatureNotAvailable", "message": "The requested feature is not available", "errors": [ { "errorCode": "MSG-242", "message": "The requested feature is not available" } ] }
looked though few post here in many mention to check account type
/restapi/v1.0/account/accountId/phone-number:
"uri":"https://platform.devtest.ringcentral.com/restapi/v1.0/account/338914004/phone-number/373220004"
"id":373220004
"phoneNumber":"+1929415xxxx"
"paymentType":"Local"
"location":"New York City, NY"
"type":"VoiceFax"
"usageType":"MainCompanyNumber"
"status":"Normal"
"primary":false
Userlevel 2
Badge
Please read this post and submit a dev support ticket.
